| 29. If replacing the rear seal on the transmission, do it now (yellow dot in 1.). Replace the drive shaft (4 x 17 mm), make sure the alignment marks are in the proper place. Torque the drive shaft bolts to 29-33 ft-lbs for the NA drive shaft and 40-47 ft-lbs for the TT drive shaft. Bolt the CSB back in place. Don't forget the spacers that go in-between the CSB and the body mounts. Torque the CSB bolts to 43-58 ft-lbs.
----------------------------------------------------- Never Play Leapfrog With A Unicorn!!! Do yourself a favor and just worry about your own car. I don't see what everyone is so worried about anyway. If someone else wants to perform a modification that you believe will destroy the value, cheapen the Z32 or whatever you can't sit on your hands about, wouldn't that make your tastefully-modified, white bread Z32 more rare and valuable? -- BradZ (FL) on December 23, 2007 at 12:19 PM The unicorn gets its revenge... -- Scotts94z32 on September 19, 2006 at 11:12 AM CLICK FOR DETAILS ABOUT BUYING A ZAMA POSTER!!!!
